Hello Autodesk guys and gals,
A really cool feature or change would be a toggle switch whether you are drawing a torus or a NBR-o-ring gasket.
the difference is: your current torus tool measures the diameter from the mid-axis of the torus section, while the size of an o-ring gasket is internal diameter x thickness of the section.
This is a minor thing, but i can recall at least 5 occasions where the false rings were ordered after this confusion.
...and while youre at it: how about rectangular/triangular/smiley-shaped/...-section areas???
