When assigning materials to components, I would like to see a tool tip added under each material suggesting the best application for that material. I know the material specs are listed under properties after the material is assign, but I am talking about while browsing for materials. As an example I was searching for a plastic or rubber as an electrical insulation but also need to know some thermal properties, If the materials had basic properties listed below ( Good electrical and thermal resistance, (within this range) as compared to ) it would save time and increase focus on the project.
