Tool Library Needs Work
I have run into two annoying problems in the tool library for CAM.  The first, that when you create a tool in one file, say a number 3 center drill, that it does not become available to you in all other projects to be used.  The second, why are there still not center drills in the tool library?  They are not that hard to make but its annoying for such a standard tool.
4 Comments
HughesTooling
If you open the tool  manager you can drag and drop tools between documents or into a library.
Just grab tool from document and drop it on a library.
Mark
ndprsha1
Thanks Mark,
I thought that when I made the tool it would've gone into my local library but I guess not.  Thanks for the graphic too.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
