currently in CAM inside Tool Library when editing a tool you can only give it one specific SFM and chip load as a "generic" base feeds and speeds. i think it would be nice if you could save those feeds and speeds into as its own entity and be able to label it like "aluminum" then during the path selection in the same menu you select your tool you also have a drop down menu for the different saved feeds and speeds you're using and it automatically update your feeds and speeds accordingly.
