Hi
Can we have to ability to add a 'tolerance' value to the extrude command?
I am modelling a shape that need to be fitted into a hole (dash board and a dial). It would be great if I could sketch the dials to size then when I come to extrude them have the option for the corresponding hole to be oversized by a nominal value - ideally from parameters.
This oversize could them be followed through and stated in drawings by using the initial sketch dimension and the oversize extruded dimension.
Matt
