To add WCS and UCS like in Auto Cad
2 Comments
There is a Ucs Command in Inventor. For Locally Coordinate System. It should be in Fusion 360. For Easiness of to work in relative
coordinate system in animation Tool bar of Fusion 360...
ballsopECAM
We need to be able to build UCS relative to the screen view or other methods for 3+2 machining work....
I would like to be able to use my SpaceMouse to set up the tool access and the make the UCS so that i can select it under the tool orientation button within the CAM Module...
Currently i cannot do this but the select UCS option is available under the Tool Orientation window.... Weird .... Almost there !!
Regards Brian.
