Show only
Search instead for
There should be an option of Along Plane It should made a Projected T-Spline along a plane by provided a option.
Like in Model Environment It cuts a body along a plane without disturbing geometry it is maintained. There is a pre built option in Model Environment otherwise it will also loose their geometry by Produced a Residual Stress of a body. But it does not looses.
We have to make an option which will constrained a projected circle of Sphere along a plane. Now geometry will not loose their shape and remain constrained along this projected circle...
Can we make an option which is able to maintain T spline Rigid or Constrained at Projected area of a Plane
Build a New T Spline as constrained without loosing Shape of Geometry
I am still skeptical of this. T splines is nothing else then under subD and this hate Boolean sin particularly when you want to later turn it into nurbs
