Showing results forĀ
ShowĀ Ā onlyĀ
Search instead forĀ
Did you mean:Ā
Finding items in the Timeline can sometimes be difficult, particularly when several components have similar creation paths. An option to present the Timeline as text would be helpful.
I can appreciate your frustration. I am training myself to rename, and sometimes group and rename, items in my Timeline. It has made it significantly easier to find what I am looking for; although, it does add time up front to the creation process and that is a bit of an issue. Perhaps, if a naming option were offered when the sketch, pattern or other action were executed that might make the process easier?
I always name an elements as I create them. Even so object labels are only visible in the Timeline when hovering over an icon. Scanning a text list visually to locate an object, or event, can be more effective than hovering over, sometimes ambiguous, icons.
You are correct that defaulting to _Label Selected_ would make the object creation process much less tedious.
