Hey you guys and gals,
would be really cool (and really basic) if one is able to make a pattern with text boxes.
Im building a laser cutting test objct with lots of laser cut slits in it, and like to engrave the parameters directly next to each laser cut. since the machinist prefers a STEP file, i'm embossing the parameters into the sold model with a text box/extrude. Since those parameters vary very slightly, i'd be cool if i could preset one parameter set, and copy it via pattern to each laser cut, and alter the parameters there. right now i'm only making patterns with the orange construction lines. Typing the (almost) same stuff 30 times is a drag...
i'm sure the eager developers at Autodesk can do this in a jiffy!!!
keep up the good work...
