Team Hub Enhancements
  • Add the ability to set Team Hub and Fusion folder and file permissions. The idea being that in a school, shop or any team environment there is likely a need to share tool libraries, machine configs, etc. In our case at least (college) the CNC Shop Professor would need full access to change or update the files (add/remove tools, etc.) while the students only need Read access so they can use the College's files but cannot save or change them on the computer they are using to access the Hub and on the Hub it's self.
  • Provide the ability to use a configurable "template". For instance, when a student logs on to ADSK (or the Team Hub?), the Post file paths would be set to point to our Hub library and machine config files instead of pointing to a local folder and file. Maybe the template also sets the local permissions ,graying out the areas outlined in red so that the students can't changes to the files after downloading them?
1 Comment
You can do this now by mapping a network with correct permissions and have fusion look at that folder
