Show only
Search instead for
Submitted byAnonymouson12-21-201803:54 PM
Status:
Gathering Support
Sweep along Origin and or Construction axis
At the moment if I want to sweep inside of a cylinder or a pipe, I need to create a sketch line. Would be nice if I could either select origin axi or construction axi that was created in the center of cylinder.
I thought an axis for plane along path would be useful in a similar way but there's a big problem. An axis has no real length, even worse the document\component axis change length as you zoom in\out so I don't see how using an axis for sweep or anything where a length is needed can work.
