Swap joint components
Hi all,
In the edit joint dialog, it would be nice to swap the two components involved in a joint.
Since the sequence of components are selected for a joint is of essence when driving a joint, it would be nice to be able to edit that joint parameter as well.
Siometimes its very difficult to swap the sequence of components using the edit dialog.
It may be an an error, but sometimes you are able to make the edit dialog just vanish, because you need to select the other component.
In complex designs it can be almost impossible to reselect the two components, to simply swap the two components with the same joint points.
A button to swap the two should be simple to implement.
Thanks.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
