Surface continuity improvement
Hi, i've found this issue when lofting surfaces. If the option "smooth" is activated, only surface continuity is ok, but not the edges. Here an example:
Thank you!
Alan.
6 Comments
+10
This drove me insane more than once and I finally ended up getting moulds cut and moulded parts made with creases in them because F360 wouldn't work right.
TrippyLighting
Currently the only way to get better control is to provide the loft with guide rails, preferably connecting exactly those edges in question.
alandmarino
Yep, i've tried that but then you cant control the tangency value.
Totally agree that there needs to be more options about how edges and iso-parms are handled in Fusion. Still not enough control over how lofts propagate.
cekuhnen
Fact is Fusion surfacing tools is far behind what other programs offer.
sadly...
loft ft cannot offer g1 or g2 for rails
patch has also many limitations like no g1 or g2 weight adjustment
and and and
promm
Thank you for your idea, we have plans to better control edge continuity with our loft tool.  When work gets started this will be changed to future consideration.
Mike Prom
Internal Tracking FUS-18087
