straight line/smoothing linking moves
My suggestion is probably only usefull for people running older machines, but when running a 3d adaptive tool path (for example) occasionally the linking, no engagement move will take a lot longer than it should because my machine can't read lines of code fast enough to take advantage of a high no engagement feed rate if it's asked to make some small movements around a corner or something.
If there was an option for either extra smoothing on non engagement (to limit amount of points in the movement) or and option to enable straight line moves as illustrated in black below that would be awesome.
Cheers,
Trav
