Hi
Many times now, because of the timeline, I have been unable to make an alteration (edit) to an object which references a 'future' object or position.
So you think you know the size you need you sketch and extrude away only to find down the line that the first object you created needs to be changed. The change is dependant on objects created later in the timeline and perhaps the position changed due to a joint. So you click on 'Edit Sketch' only to find the later objects have disappeared and can't be viewed let alone referenced.
What I am proposing is that all objects created or re-positioned later down the timeline are visible across the whole timeline irrespective of when created and therefore can be viewed or referenced (projected from) during sketch editing. Perhaps able to toggle this function as necessary.
Matt
