STL export in main menu
Please put STL export in the mail export menu or save as. 3D printing is here and probably going to be the next base for your programs.
6 Comments
HughesTooling
Just want to ask, you do know there's a save as STL if you right click the top component or any sub component or body.
Mark
ewingl
Also, if you click the "3D Print" button and uncheck "Send to 3d print utility," it will save an .stl file. 🙂
This definitely should be more evident though...
daniel_lyall
@ewingl do a wright up in tip's and tricks
MontyFlange
Yer I know it's hidden in that drop down mwnu system. But seeing as it's an important file type it should be in the main menu.
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
