STL & OBJ format file save
Sometimes when working in fusion 360, there are some bugs pop ups with some identical messages. when sometimes when I start model making sometimes due to high rendering a dialogue box which shows tow options, these options are not responding and send report. the main reason of the pop up of this dialogue box is due to inappropriate installation or inappropriate requirement of the system or when the bug is not fixed properly.
The options appear into this box is not helpful because when we will click on the not responding option then suddenly it start with pop up of other box which shows some signal  that send report to Autodesk. Apart of this the another option that is send report, as we click on this option suddenly fusion 360 get closed and again if we click to launch fusion 360 then sometimes it takes time about 7 to 10 minutes to complete start and to show user interface.
There are several alternate solution to this problem, these may be caused due to incomplete installation of the fusion 360, as to fix this problem one should re-install the software followed by downloading it again, also check the appropriate requirements while downloading the software, as to set up in 32 bit or 64 bit,
keep in mind one thing that going to higher versions may change the size of the file. So one is suggested to check capacity of the system before downloading and installing the software.
If this troubleshooting is not working them open the task manager from your windows and check that how many times the fusion 360  and the fusion launcher is been running, then close all by stopping the task properly and again staring the fusion . So these are some solution of this trouble shooting problems with their solution which are caused in fusion . For another ideas and solution visit my page.
