stay in background on load (please please fix)
This is a pet peeve of mine, because I can't "pre-load" Fusion while continuing to do other things. I have to load Fusion 360, and wait for the annoying "always on top" load screen to finish loading the program, because it obscures all my other work windows. I searched the idea database and there was a request for this as far back as 2013, but it was archived without resolution.
5 Comments
Did you try to use "Windows + D" shortcut. Should hide it  🙂
Best regards,
Krzysztof
Krzysztof, thanks - your suggestion does work. Alt-tab doesn't, but showing the desktop does. This is a viable workaround. However, I would still hope that the loading screen be modified in a way that it doesn't pull to the foreground (for the sake of UI experience). Thanks!
pior_o
Yeah, there shouldn't be *any* full screen wait screen while a program loads. There may be workarounds, but they are irrelevant to the problem itself - this kind of UX choice has to go.
colin.smith
Status changed to: オートデスク今後検討
keqingsong
We've been tracking this issue for quite some time and haven't been able to reproduce it in a while. Is this still happening for you? If so, can you share with me your system/OS specs?
