Right now holes are pretty customizeable, but there is one big problem that I have, which is that there is no standardization. For example, if I wanted an 8 mm counterbored clearance hole in a part, I have to manually look up how oversize the hole should be and enter that information. What is missing is that all of these dimensions - clearance holes, counterbores, etc, are standardized! A much simpler workflow would be to select from the hole standard and then it would automatically generate a clearance hole for an 8 mm bolt, with options to counterbore said hole to the standards that it complies with.
As shown in this image, all of these dimensions are essentially freeform right now, so I either have to guess or look up counterbore dimensions.
This would make the usability of the hole tool much simpler and quicker - instead of looking up counterbore and clearance depths and diameters for a 10-32 or for whatever bolt I am using every time I need to make a hole, this feature would function just like the threads feature, which has all the standards listed as shown below. Then it is just a matter of assigning all the other parts of a hole to those standards, other than just the taps.
