Spring should be flexible when fix at one end and extend other end.
3 Comments
Spring should be realistic in this modelling environment after joining to a component  it should be have a flexible property as in realistic exists. It should change its property according its stiffness constant K value "Hooke's Law "
There should be same for Rubber and Cloth. They should be Flexible also. And stiffness should be given to them..
keqingsong
Than you for your idea. Yes, it "should", but making that happen is a long way's out because the math + code to make this happen is a huge undertaking. We have higher priority projects we are working on at this time.
