Split Body Remove
Split Body Remove
How about when we right click on the split body a flyout is available to remove it as opposed to going thru list and removing it from there. That would speed workflow up tremendously.
1 Comment
The splitting tool as in other CAD system show an arrow, so you decide wich side you keep, also it will be nice to be able to use more then one splitting tool.
an exemple:
1- I need make a extrude,
2- I need an array from it
3- then I actually need to combine the array resulting bodies
4- Ten split it with one surface on top side
5- Then I split an other shape on bottom side
6- then I need to remove the useless body on top
7- Then remove the useless body on bottom...
It should be instead:
1- I extrude
2- I do an arry, and I activate a combine result check box
3- I split with both, top and bottom surface limits, and just have the center result body left.
Yan
