I am working on a project currently which ultimately will be 3d printed
For all intents and purposes, if you were looking at the end of a u shaped channel, and wanted to add what used to be called flying buttresses to support the outer walls from the inside section, how does one do it easily?
I was thinking that the draft tool is perfect, but it lacks the provision
Draft works perfectly for what it was designed to do. But what if you added some features. Such as:
Width of draft
Start position from a plane in mm/in
Additive or cut
