Snap to Quadrant unavailable while sketching
While sketching a centreline in a circle I cannot snap to quadrant as I do it in auto-cad. It is very difficult to get accuracy. On sketching a line snapping to intersection or end point on zooming I find it at a offset. Hope you will add the snap on quadrant feature immediately.
Secondly I had request for Sheet metal feature enhancement in fusion, but my fusion team is taking a very long time to incorporate the same. I am very confused whether to continue with fusion or switch-on to some other advanced and parametric software.
The structure component are also absent. To draw a structure I had to refer the table for Flange and Web details. I do not compare fusion 360 to Tekla structure but you can add the structural library with properties like in solid works.
Hope you will consider my request and not keep ;me confused.
Warm regards
Dinesh Puthran
1 Comment
HughesTooling
If you want a end point of a line at the quad point add a vertical or horizontal constraint. First pick the circle centre point then the line end point. The request for quad snap point has been requested before a few time, don't know when or if it will be added.
Here's an example adding a vertical constraint.
One last note. When you make an Ideastation request the the guidelines above your message say one idea per submission. Posts with more than one idea usually just get archived.
Mark
