Snap to Perpendicular Offset Plane while Sketching
The pictures say it all, but I'll add more.... in the first picture, the vertical offset plane aligns with the grid so anywhere else on the sketch it will snap to the grid but with the green line/X (words escape me) it won't snap to that grid line.  In the second picture, the offset plane is not aligned with the grid and also cannot be snapped.
I'll work around it but it'd save me time being able to use offset planes for snapping references in sketches since the planes go through multiple components I want to modify along that reference.
neither is it snapping to offset plane apart from grid line.pngneither is it snapping to offset plane apart from grid line.png
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
