Slow down the overall speed interval of Motion Study
I feel like the current values you can set the motion study speed interval to is far to high. I always put the speed slider to the lowest setting, but it is still almost always to fast. And putting the slider at the fastest setting makes it impossible to even see the frames playing. For my project, I have to put it at roughly 1/5 of the speed to even be able to make out the intended movement.
I feel like this should be a pretty simple fix, possibly just tweaking the values. Another solution that would be appreciated is the possibility to add more then just a 100 steps. Then I could spread the intended movement out on a larger span of frames .
The linked video shows the movement I'm trying to recreate "Linkage for Parallelogram's Tracing"
https://youtu.be/lXO69eRWkkY?t=4
