Skip loading times!
Skip loading times!
I get that fusion360 needs to process a lot of data when doing a lot of actions but I get crazy. Projecting or extruding a complex sketch, for example, is always suuper heavy. And If I select the sketch it loads a long time. I change a parameter and it loads again, changes it again, loads again.
Can we please make it possible to pause the calculation or "preview" so we can adjust the settings to whatever we want.
For example,
I wanna select the body, the sketch, that it should extrude cut, how far,  It should extrude from a face.
That's 5 actions, basically 5 loading time when it could be only one if we change this!
Please implement this.
