Sketch projected areas on/off
Sketch projection areas on/off
a check box that you can uncheck when you draw inside of a sketch, so when uncheked, you can just select the areas that are inside the sketch, because most of the time, I don't like the fact that the sketch selectable area are devided automaticly with any features that are on the same working plane, this should be optionnal to allow me to choose if i want this of no.
thanks
