Sketch orientation
Sketch orientation
I have attached 3 screen shots of this problem. The cut out in the bracket was put in for visual reasons only. You can see in the last screen shot the bracket has re-orientated 180 degrees after selecting the sketch plane. This is a problem as you could start working away, unaware that the model has rotated, ok if your work is equi-spaced around the brackets centre line but not otherwise. When creating a sketch plane the model must remain in the selected orientation.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
