Show only
Search instead for
One should be able to see all of the sketch elements (lines, circles, points, etc.) in the treeview hierarchy, One should be able to make subgroups for all elements from top to bottom. You should be able to select anything from the treeview.
Just my $.02 but my sketches tend to end up being fairly complex and large, and the feature tree and timeline can already get really large. I see no need to be able to select "line72" from the feature tree instead of just clicking on it.
Spam detection software, running on the system "craft.baggett.org", has identified this incoming email as possible spam. The original message has been attached to this so you can view it or label similar future email. If you have any questions, see the administrator of that system for details.
Content preview: Sometimes, lines can overlap and then selecting the correct one becomes impossible. Sometimes a dark line on a dark feature is impossible to see and thus impossible to find to click on. Sometimes, the model is very busy, and clicking on the correct line is difficult. Line behind a plane? Behind another object? Trying to merge two points that are nearly on top of each other, but not entirely? Etc. [...]
pts rule name description ---- ---------------------- -------------------------------------------------- 1.2 MIME_HTML_ONLY BODY: Message only has text/html MIME parts 0.0 HTML_MESSAGE BODY: HTML included in message -0.3 BAYES_05 BODY: Bayes spam probability is 1 to 5% [score: 0.0349] 1.7 RDNS_DYNAMIC Delivered to internal network by host with dynamic-looking rDNS 0.6 MISSING_MIMEOLE Message has X-MSMail-Priority, but no X-MimeOLE 0.0 HTML_MIME_NO_HTML_TAG HTML-only message, but there is no HTML tag 0.2 HELO_MISC_IP Looking for more Dynamic IP Relays 2.0 XPRIO Has X-Priority header
@tima123d If two lines are overlapping, left click and hold the button down and you'll get a popup allowing you to select entities that are under each other.
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
