Simulation : error message more explicit for beginers
When you happen to be wrong on the constraints of your model, you'll often end up with error E5000 and component x error  (1, 2, 3, 4, 5 or 6)
It would be easier for begeniners to explain the errors and the possible cause (model not fully fixed, etc.). People trained with simulation know them, but beginers do not.
Something like this at least would help a bit :
Component 1 (constraints are not correct on the X axis)
Component 2 (constraints are not correct on the Y axis)
Component 3 (constraints are not correct on the Z axis)
Component 4 (constraints are not correct. The part is rotating on the X-axis during calculation distorting the result)
Component 5 (constraints are not correct. The part is rotating on the Y-axis during calculation distorting the result)
Component 6 (constraints are not correct. The part is rotating on the Z-axis during calculation distorting the result)
