Simplify Capture Image
Would it be possible to simplify the sequence of events for capture image?
Either move ALL the setting stuff to preferences or create a new "Capture Image" button with a pull-down for the options
    Make uploading the captured image to the cloud an option (I.E. do you want to upload your captured images to the current folder?).
    Make the image type (Png , Jpg or Tiff) a settable option (I.E. what image file type do you prefer?)
    Include all the image options as well
    Etc. (There are probably other settings that could also be moved )
Second - drastically reduce the number of mouse clicks / key strokes required to capture an image.
    Current sequence of events
        Orientate your design (anything from 1 click up)
        Left click the "file" button
        Left click "capture image"
        Left click "Ok" (this assumes that no changes are needed for the image options)
        Left click the little almost invisible button with 3 dots next to the big bright blue highly visible "Save" button
        Choose the folder where you wish to save your image (anything from 2 clicks / key strokes up depending on folder location)
        Left click "Select Folder"
        Left click "Type" field
        Left click "JPG files (*.jpg)"
        Left click "Name" field
        Enter a new file name or add an image sequence number to the end of the existing file name (from 2 clicks / key strokes up)
        Left click "Save"
        Then 1 or 2 clicks to reorient your design
    So - for the first image into a folder, Fusion requires a minimum of 15 mouse clicks / key strokes
    For each subsequent image into the same folder Fusion requires a minimum of 12 mouse clicks / key strokes
I.E. to capture 10 images of a complex part - I have to use an absolute minimum of 126 mouse clicks / key strokes
Brett
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
