I have Keyshot and SimLab. I use Simlab nearly exclusively. Simlab uses the same rendering engine as Keyshot. It has pretty much the same capabilites but costs a fraction of what Keyshot costs.
With Simlab's new physics engine simulatons on my assemblies are easy and fast.
My question is why doesn't Autodesk use Simlab instead of Keyshot or at least also. I think for the demographics of Fusion 360 Simlab would be a better fit.
No connection to Simlab. Just a very satisfied customer and thought I would give some of you a heads up on Simlab.
The reson I don't use Keyshot more often is it is a real time rendering setup so it hogs resources when it really isn't necessary. Simlab will also work in real time but you can set it to render only when you want.
