Show rotary axes in simulation
When you are doing 5-axis toolpaths it would be helpful to see the rotation angles at different points of the toolpath. In the info section when you simulate, and when you do show info on the toolpath, it shows XYZ coordinates but it doesn't show ABC rotation angles. That could be helpful to know you aren't going to overtravel your rotary.
1 Comment
Buongiorno vorrei sapere per favore come posso installare la lingua italiano in fusion 360 Grazie
