Show Radians for Revolute Joints
When you're working on a model and you've got a Revolute Joint that's visible (i.e it's lightbulb is ON in the browser) and you manually grab the rotatable object and rotate it or just select the Joint, it very nicely shows the angle of revolution, in degrees.
However, if you're also working on a script that will access or control that revolute joint, all the values it deals with are in radians. I think it would be very helpful, when manually manipulating the joint in the model, that it not only showed the values in degrees but also in radians.
