I work on drawings with a great many sketches and bodies, drawing these together into components late in the day, as they are of many moving parts, and "fit" and relative-movement always needs a certain amount of "fettling".
Idea: It'd be very handy if keyboard shortcuts existed for:
Scroll to last sketch ("shift-ls"?)
Scroll to last body ("shift-lb"?)
Scroll to last component ("shift-lcm"?)
Scroll to last construction ("shift-lcn"?)
For those of us with programmable keyboards this would be a godsend, to save time mouse-wheeling down huge lists. "last" means end-of(sketch/body/component/construction) list, not "last used".
Also, could we add a method by which components made on a "central assembly-drawing" can be copied into the parent directory as a linked component, with the option to nominate which of the two should be the authoritative design. This would be helpful when parts are designed on a large assembly drawing and then need to have separated out to individual part drawings.
I'm a relatively new user, so apologies if these already exist.
