Shift + Move command to duplicate sketch (objects)
Every other 3d application has the option to duplicate an object by moving it with the shift (or other) key pressed. It would come in pretty handy if I could duplicate sketches that way. Bodies and Sketches would be even better of course. You could also take into consideration of having the option to create an array that way, like for example 3ds max does.
1 Comment
untrustedone
Just to pile on a bit, being able to select a path to duplicate objects along would be very nice.
