Ok,
This concerns the behaviour of the Shell feature within Fusion 360. Its biased towards the limitations of CNC milling..
Below is a before and after of a 2mm shell application:
i would like the shell tool variant to be able to Shell a face while:
1 -"leaving" a fillet of a predetermined radius on specified edges..
2- not undercut unless permitted
3- not leave crazy voids/thin/impossible to machine holes.
I don't know about other designers/machinists, but i tend to use the shell function a lot to lighten the part.
When modelling in fusion and using shelling, i always find myself adding in fillets afterwards.
Imagine real CNC machining. What material in the form of fillets are actually left when pocket mill/ shelling say a cavity with a 10mm ball end mill?.
Many (most) times I don't machine out those R5 fillets, it takes time, tool changes, very little weight loss. Plus they help eliminate stress/fracture points/risers - let the CAD package capability reflect that reality. My designs are manufactured in-house. Currently i have a small, manual tool change, 3 axis machine - i dont design what i cannot machine.
To achieve this, it would (or could) behave just like a 2.5, 3, 4 or 5 axis machine can.
You would have to specify a "behaviour" in options:
1- "flat end mill mode - only leaves a fillet in the Z plane?
2 - ball end mill - leaves a fillet always, on all edges (but no undercuts if limited to 3 axis behaviour?)
3 - bull nose mill - leaves a fillet too, but a different size in the Z axis.
4- weird hybrid mode for 4 axis/5 axis... enabling undercutting and other headaches.
When you would specify tool/fillet diameters:
1- it determines the diameter of fillets left
2- it prevent unachievable machining features such as those seen above - like shelling deep into pointed corners of much less than 90 degrees etc.
If the tool sizes are specified then tool cant pass down these pointless paths.
A "crevass" or pointless shell area elimination/option:
to prevent the shelling option taking it too far, by specifying a minimum shelling area or volume. For example it could stop shelling machining between an array of holes? (the tool radius parameter could prevent this happing too).
i hope this makes some sense. I feel it would be a nice feature and reflect how we design and machine in the real world.
Bruce.
