Would be nice to have 2 features added to Sheet metal side.
1. Close corners command similar to how solidworks does. You can select corner faces and then pick how you want the corners to overlap or butt up to each other. Now it seems have to use offset face tool on each corner face to close up a corner and it takes awhile and doesn't automatically update if I make changes to metal thickness etc.
2. Offset flange. In addition to inside/ outside/ adjacent, there should be an offset selection to extend the flange out from the current edge. This should also work with the symmetric/ two side edge selection. This would make it easy to extend a narrow section out from a wider edge. Would save having to do a seperate cut command on a longer, wider edge.
