shapes other then a pipe ( e.g.helix) that can bend along a spline
Today I can overlay a pipe design over a spline and bend any way I want... easy.
What is not possible is to change the design of the pipe-surface...apparently one can't add material to or remove material from the pipe-model which is present in the fusion 360 "create" function. And if you could... the pipe will no longer bend along a spline.
Attached file clarifies the situation.
I was trying to model an old classic double helix covered Rebar and overlay this over a spline so I could be bend anyway I want... just like in the "create-a-pipe" function.
Why can't we add custom shapes  to the "create" function and twist and bend these just like the pipe model.
thanks, Piet
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
