Set scale point manually
Be able to manualy select the origin point ofr scaling same way you select the pivot point in Move .
3 Comments
quentin
you can but does not work like the origin point in the move comand. the "scale" dialog's second line is called "point" if you click there then it lets you pick a point on your model to scale from. Unlike the move which can be moved anywhere there must be a point on the object to be selected.
KirillChepizhko
Yeah that the point of my suggestion. It doesnt work as well as in the Move
command. But it should
keqingsong
Status changed to: RUG-jp審査通過
