Set of Reference Axis Labels that rotate with the model
Axis Labels were requested before & the solution was the colour-coordinated axes.  I use various programs with colour coordinated axes and they are not all consistent, but they are all labelled.  Labelling the current origin & component origin axes is not a great solution too because they are off by default and also sometimes hidden by the geometry.  A reference triad that rotates with the model--Even something in the view cube--would quickly let the user get his/her bearing.
4 Comments
Example Workflow,
Currently:
"Let me turn on the origin I want to mirror the component in whatever plane that is. I can't select it. I'll expand the origin in the browser. The Y-Z plane highlights. I'll pick that."
With a Reference Triad in the UI:
"There's the Y-axis & Z-axis--I want to mirror the component in the Y-Z Plane. Can't select...  I can select the Y-Z plane from the Origin drop-down in the browser.
"EDIT:"Smiley Frustrated
Example Workflow:
Currently:
"There's the Y-axis & Z-axis--I want to mirror the component in the Y-Z Plane.   I can select the Y-Z plane from the Origin drop-down in the browser.
Hey!!!  It's in the Simulation environment; why couldn't you have put it into the Model environment as well?Smiley Mad
keqingsong
Thanks for letting me know!
