Set keyboard shortcuts for activate and isolate
Hi there,
it would be nice for a way faster workflow in big assemblies with sub-assemblies to set keyboard shortcuts for activate and isolate.
cheers
Kevin
4 Comments
SolubleSpork
It would be nice to have shortcuts for toggling visibility too.  The less I have to click through the list of components and things to get what I need done, the better the workflow.
Cheers
-Also Kevin
Hello! I developed an extension which puts isolate in a menu so you can shortcut it. You can also shortcut unisolate 🙂
Per your request I also added Activate, which I can 100% see myself using, thanks for the idea!
Actually, the most useful thing I found after using this extension for a while is the find in browser shortcut.
My sights are set on Edit Feature, but I don't know how I could do it with the API as there are like 100 edit feature commands for each different feature.
You can download it from https://github.com/lf-/ShortcutItPy
SolubleSpork
@Anonymous You deserve a medal.  Thank you.  They probably should still add in this functionality so that we don't have to rely on an add-in.
@Anonymous Thank you for the add-in, however, I can't seem to find the option for Activate under the drop down menu.
