Set bottom face for 3D print
You do not always 3D print a piece the way you build it !
So it would be cool to be able to choose the face that should be the bottom.
Better would be to choose the construction plane that should be the bottom and if there are angles <45° that the export to STL panel show options to directly build supports (meshmixer type 😉 )!
This would save us a lot of time.
In fact Fusion 360 SHOULD HAVE a 3D print mode (like sculpt, sketch or form...). It already has a CAM mode why not a 3D print mode ! 😉
Thanks !
16 Comments
daniel_lyall
just turn it around
and you use meshmaker for 3d printing so why add to fusion when that what meshmaker is for
odolyte
When you have complex models that needs to be split up before printing like i do i don't want to tear it apart in order to print it. I want to be able to keep it in place but also to print it the way it should.
If you know Meshmixer, building support for 3D models is not its purpose but it happens that it has a good support construction. The two functions that i would take from meshmixer is suports + Stability for models to stand straight up.
I thought that Fusion 360 wanted to make the bridge for makers, engeneers and designer to directly go from modeling to building (if not why the CAM mode ?). If so i think that letting 3D printing apart is a huge mistake.
Lots of us 3D print models, so yeah having a 3D printing mode in Fusion would save us (or at least i think a lot of us) a lot of time and would be exactly in the philosophy of Fusion 360 : 1 tool to make (almost) everything (i didn't say one tool to rule them all 😉 ). Bridging between Designers, Modelers, Engeneers, makers...
daniel_lyall
good come back I will except that
odolyte
Thanks for supporting this Daniel !
daniel_lyall
3D printing is something I don't do and probably wont but your idea make sense fusion being a almost all and all program since I am getting use to using it since I can do cabinet making with it now it surpasses sketchup for me now
odolyte
I agree. I really love Sketchup, but it really can't compare to Fusion 360. Fusion has a more difficult learning curve but has so much more to offer.
Now i nearly only use Fusion 360.
just turn it around
colin.smith
Status changed to: オートデスク審査落選
Thanks for your suggestion. There are a number of ways that a part can be oriented on a plaform and this idea is worth investigating.
With regards to a dedicated 3D Print workspace in Fusion360 - that work is underway right now and should be released in the second half of this year.
Colin
odolyte
Thanks Colin,
This is good news !
Hey Colin,
Just wanted to add that meshmixer supports haven't been adequate for when you need a truly flat overhang. Please look at Simplify3d's supports as they allow very accurate overhangs to be placed on top and they are extremely easy to remove.
Thank you
Luke
odolyte
@lukepighetti : true out of the box but simplify 3D consume a lot (really a lot) more filament for the supports than meshmixer. If you set the right parameters you can reach very flat surfaces with meshmixer too (slow bridging + little under-extrusion + high fan cooling). Simplify 3D is more "easy access" than meshmixer, more... surgical...i'd say...
Well, for some reason, on Yosemite I can't even change parameters to adjust the support structure! It just goes 'bonk bonk bonk' when I try to generate custom support geometry. 😞
I have had poor luck with the 'default' support strategy... either way, supports would be an awesome addition to fusion! (I draw them in by hand right now)
odolyte
@Anonymous : "either way, supports would be an awesome addition to fusion! (I draw them in by hand right now)" > completely agree but hopefully Autodesk is setting this right... Let's wait and see 😉 !
cekuhnen
Wow great news Colin!
Yeah even though we haven't been doing FDM in a long time, that's great to hear (and will very useful for any kind of prototyping / manufacturing if it's done right).
jeff_r_latham
I agree. 3D printing should be included in the CAM workspace. It can generate toolpaths for subtractive manufacturing, why not additive manufacturing as well?
I know that Autodesk Print Studio is trying to fill this role; however, it does not have the ability to set several crucial/non-trivial/must-have settings for 3D printing (such as extruder temperature and telling the print head to lift off of the part before traveling). So as of right now, Autodesk Print Studio is a very pretty yet completely useless piece of software, which is sad because I want to use it.
So, Autodesk should focus on making Print Studio a functional application, but there's also no reason to not include additive manufacturing toolpath generation within Fusion 360 itself. This would take it to the next level!
