Separate No Drag turning for Rough and Finish
Separate No Drag turning for Rough and Finish operations.  Currently, when I select no drag it is applied to the rough and finish pass.  When cutting softer materials like aluminum there is no real need for no drag roughing and it only increases cycle time and machine moves.  However, on the finish cuts I want to run it since I can't drag up the face leaving .015" stock.
I have been breaking it up into 2 ops for a workaround.
