selected objects appearance
hi, i'd like to be able to select an object then right click>edit appearance.
at the moment the appearance box opens with all materials shown. You can right click on the material to select the object, the inverse of this is whats needed. (i.e. right click the object to find out and edit its appearance)
The issue is when you have too many similar materials in the "in this design" material box. clicking thru 20 similar materials to find out which is which is applied to what object isn't efficient.
