Saves on Undo list
Saves on Undo list
It would be hopeful if one can see moment of saving on undo list. I sometimes want to revert to last save state and reopening doc is quite time consuming.
3 Comments
hoegge
This is a very good and useful feature which is badly needed. The action "load" should also be added, so you can easily go back to the original load when you started working, i.e. the original state of the file. So if you have saved multiple time there would be a "Save v11", "Save v12", and "Load v10". That would be very useful every day
hoegge
Any thoughts on this - still would like to see what changes was made since last save, to determine, if I should save anew version or not. Why can't you just put a "Version saved" in the undo liste?
hoegge
And what is even more important. This would make you see if you HAVE saved or not and if anything and what happened after last save, to decide if you should save again or not.
