This might be a pipe dream, but I would love it if you could save a DXF (from a sketch or from a face) and in addition to generating the DXF it would add:
- Two outside dimensions (extents) so that the laser cutting shop can verify scale
- Have a text block put in below the DXF profile listing: Part Name, Part Material
Those are typically the things I have to go and manually add to each DXF to ensure that no one screws up the parts. It's the same steps every time, so having it be a default setup option for the 'save as DXF' would save me (and likely others) a lot of time.
