Rule Fillet: Max Radius Indicator -and- Show Offending Geometry.
When utilizing the "Rule Fillet" function in the modeling environment, there need to be two check boxes in the options box:
1st: Indicate Max Fillet Radius.
This would offer a size value as a text indication of what the max radius would be able to go to for the selected shapes.
Currently I need to enter random values or drag that slider thing, and HOPE it doesn't exceed bounds and generate Fusion's warning message.
The slider is usually useless, as the slide amount quickly exceeds the max value allowed, which then requires me to wait for Fusion to realize this, indicate the warning, allow me to adjust and all this can take a few minutes depending on the complexity of the design.
2nd: Show Offending Geometry.
This would offer a BRIGHTLY highlighted indication of WHICH shape is the one that creates the issue for the Rule Fillet, so I can deselect that one and apply to rest. Then I can fix the offending shape and apply the rule fillet.
These are just some things that would make my life easier.
Alldaron
2 Comments
colin.smith
Unfortunately this idea did not get the support of the community and as such we will not be pursuing it. Please feel free to rework and resubmit this one down the road. Thanks for taking the time to submit your idea. Due to the low strategic fit, we have decided that we will not be pursuing this one at the given moment.
colin.smith
Status changed to: RUG-jp審査通過
