Rib function with curved surface
would it be possible to extend the rib function so you can use this tool also with curved objects?
I tried every trick here and Fusion only lets me add ribs when the object is flat and not curved.
even projecting lines onto the curved surface does not work - I cannot select them as an input data for the rib tool
1 Comment
keqingsong
Status changed to: RUG-jp審査通過
