Retrieve dimensions from model into drawing
I would wish to have the option to retrieve the Dimension which I already have specified in the 3D-model, directly into the 2D-drawing. This to avoid having to manually add the same Dimensions to the drawings as I already have specified once before in the model. This would save a lot of time creating drawings (at least for me). As a minimum it should work for sketches, but in the end I would like to see support for also Extrude, Hole, Pattern, Thicken, Fillet, Chamfer,etc.
This should be an option, so you could still Dimension manually.
See Pictures below from Inventor where this is possible.
1 Comment
TimeraAutodesk
